- where to get head flange for b-series?
- str?
- b16a intake on ls ?????
- hondata gasket leaking
- Ls/GSR block
- The 420 motor
- What next?
- problem with trans..
- AC problems
- B16 Intake Manifold on GSR
- help..
- Help with Ls swap please
- spoon headgasket?
- where can i get these....
- Help with H22A1 codes
- Motor Help
- Un-mini-me swap
- mtr mount inserts ..
- engine smokes, help
- Ls All Motor Question
- roll cage question..
- good buyer!!
- d16y7 intake manifold. .
- who knows
- this easy to install
- pg7 computer
- timing marks
- sohc turbo setup
- Installing OEM power windows
- O2 Simulators
- help!!!turbo and mani dont fit
- sticky calipers
- Radar detector/Valentine one question
- wat should i do to my motor?
- Crank Pulley
- anyone know??
- 01 integra gsr
- Head Swap ? (sorry if its a repost)
- wiring question..
- Leaking EGR gasket=erratic idle??
- better idea?
- Honda Valvespring keepers
- Project h22a prelude
- one piece front end
- shifter bushings
- What a difference!
- Loud squeeling when starting up..
- help me help me.stuck
- Anyone have leftover d15b7's from swaps?
- car idle at 200rpm...
- fuel line ?
- I Need Ls Or Gsr Mount Brackets
- problem wit swap
- mtr mount question
- fuel question?
- f22 question
- head gasket
- valves
- Woohoo! a special thanks...
- Clicking noise...
- In-ground Alignment Shop???
- head pressure?
- D15b1
- valve tick?
- ctr pistons in 96 gsr?
- kg edelbrock ?????
- Need a ls Block!!!!!!
- Air Intake Question
- big problem
- ls shift link..
