- Grassroots Motorsports is looking from a stock 1st Gen CRX!
- civic help...please
- da help
- Spoon Civics
- having issue with new headers
- need help asap please!!! obd0 to obd1 jumper harness
- H22 ac
- my eclipse smokes all hondas!!!
- d15b problem HELPP PPLEASEE !
- 93 civic fuel issue
- door leak
- B18a1 motor build questions
- need b series cv axle for driver side a.s.a.p
- i kieep burning my ecu????
- looking for help with turn signals....
- eg auto problems
- d series swap
- H Series In Accord
- Wtb!!! Eg Coilovers And 4 Door Fog Lights
- 98 civic 1.6vtec starter replacement
- non-vtec to a vtec 16
- oil amount
- New guy from NY...need some help
- $450. Need H22 Swap In Accord
- clutch is screaming at me
- where to get a d16y8 street tune
- 98 Prelude driver power window
- 16x8 et 38 fitment on ek
- supercharged wagon
- Map sensor help d15b7
- cv joint problems and questions
- Clutch problem?
- which is more economical?
- polishing a mugen valve cover
- Broke the screw that holds my 2000 civic foglights ground wire inside the light itsel
- Doing a wire tuck?
- ls conversion
- i need a dohc zc head gasket!!!!!!
- No check engine light????????
- Need Help. Please read!
- Help!!! Ls Vtec Bogs When Given Gas!!!
- Car idles too high? b16
- wire harness issues
- Get my A/C working and I will give you a car
- ac wiring problem
- gsr cant rev pass 4k???
- A/c lines in eg sedan Dont fit WHY????
- how to install a camber kit
- H22 Turbo with A/C?
- skunk2 intake manifold
- buying a d16a6 call me
- if the engine light does not blink?
- ? for experienced tuners
- Car stumbles and overheats! Need help!!
- car bogs over 2krshared_pm....with clutch engaged
- car starts then shuts off
- valve seals replaced, still smokes
- ef hatch conversion?
- Jdm.???
- Ek & Eg...???
- mini me help
- Need help Map sensor issues.
- Please Help! I need a 14-15mm Fine Thread Bolt Will Pay!
- killswitch help
- Rear diffuser?
- ls swap to a 98 ek
- what header will fit dhoc zc on 1989 integra
- i need a tune!
- K20 pistons?
- flames good or bad??
