- block and head combo question.......
- 95 accord swap
- car want pass 4000 rpms
- 5lug conversion acura integra shakes while braking help!
- Ls startup problem obd0 ecu code 5
- CEL Light Code 15 help
- Car Startup Problems And Scenario!
- WTB: 96-00 dx coupe headliner
- Are type r retainers the same as b16 or gsr?
- need help: 4x114 spare tire
- need o2 wiring help
- misfire at idle ls/b18b
- ***wheel restoration ??? Advan RG1***
- Hazard lights but no turn signal?WTF?
- Painting my EG, torn between colors. Help??
- Laminova A2W Intercooler design?
- ls t bracket help is da the same as dc
- H22a1 into 1994 Acura Integra GSR Question
- need help. throw out bearing rubs on pressure plate
- 90 integra build advice
- Need exhaust ideas. Good flow and quiet.
- intermediate shaft question..
- No spark in 2 cylinders
- need help on my exhaust on my h22 eg coupe pls help
- DC2 Parts ?
- need help
- ls/ vtec bearing???
- Eg Coupe In Riverview ????
- Windows won't go up.
- cant figure it out
- o/2 sensor wire....
- Bypassing clutch safety switch - 1991 Acura Integra
- zc dohc
- Popping on Decel.
- Turbo manifold design?
- fuel press./Nitrous
- 89 Prelude SI Question
- HELP. missing after miss shift
- 5 speed swap or trade?
- Please Help!! New Clutch Issue...
- quick pcv valve question....
- OEM bigger brake help
- Anyone know this car? EG ITR hatch
- Front Left Wheel Leaking Brake Fluid
- please help b16 turbo b18c1 turbo
- need help, will 92-95 neuspeed race springs work on ek
- Compressor map questions...
- Why are Vitara's so strong?
- NEED HELP! My DD wont start, just shut off while driving.
- H22 cam help
- Very strange starting problem with 97 Prelude, very random...help!!
- gas gauge (90 dx hatch)
- Brake Light Switch
- d16z6 comp cam stage 2 problem
- Motor Oil
- civic spring lengths
- need some acura help
- speedo and rshared_pm issues on ek
- 'Extreme' Compression needed for SOHC NA power?
- civic not starting??? help!
- Question on arp bolts help
- Need help Plz read if you have a b18c motor.
- B18C1 into EG civic problems...
- TR need help dc2 wont start
- looking for a shop
- first honda..some issues.
- Question about Edelbrock kit on EX?
- How To Fix Bad Ground?
- b18 swap driver post mount ? please help
- Wtb. Looking for Civic keys
