- b18b & rwd
- MSD Blaster Coil?
- good port and polish?
- cam gear ?
- Spoon Sports N1 Racing Silencer Exhaust
- Greedy TT help...
- PRELUDE
- Loacal shop to do Level 10 PTS upgrade?
- Another clutch question...
- underdrive pulley
- Local shop that will do tranny swaps
- AEM Intake
- Another big question...
- RS---> ITR suspension
- Tuning Fuel Settins W/ VAFC
- Lightened flywheel?
- Road Race in Gainesville
- machine work/skunk2 ?s
- will 1.6 ex vtec head fit on 1.6 dx block?
- please help
- Header
- Sway Bar
- wheelwell lights
- Transmission Question
- What would you do...
- question
- Specifics of ITR and SKUNK2 Intake manifolds
- CV Joints for 93 Integra ??
- Need shop recommendations quick!!!
- Suspension problem
- my v-tech
- JR supercharger vs. turbo
- Local Parts source?
- All motor set-up
- where to find zc
- Putting a turbo on a GSR
- Odd Question..
- cam gears and detonation
- will this work?
- Itr Cams questions...
- Shift Knob Replacement for 01 5spd Accord
- Which are the best coilovers
- question about prelude test pipe
- Will a 1.6 tranny bolt up to a 1.8 block??!?
- Clutch question
- HYPERCLUTCH?
- T3/T4 Hybrid Turbo
- gs-t turbo
- Best turbo motor
- Civic suspension
- D16Y8 turbo kits
- overkill?
- B16A3
- Vacuum connection
- J&S Install
- coolant smell
- problems with civic electrical
- will this work???
- header
- fatter piping?
- block guards
- Would it work...
- Check out this GUYS 319HP integra!
- auto to 5spd Its alive!!!!!
- help fast....
- The order of the mods I should do
- yo john
- Whos the best in town on wiring a APEXI VAFC
- dual exhaust?
- CTR Intake Cam vs ITR Intake Cam
- Short Shifter Question Good/Bad/Which One??
- My nitrous FAQ
- allignment results & opinions...
- throttle body
- konis
- Prelude engine
- CTR Intake Cam & Cam Gears & Vafc
- Spoon or Toda
- 90-93 teg front brake work on 94 up teg?
- test pipe and o2 sensors
- OBD 1...
- Will the...
- D16 vs. B16 Injectors???
- Crank Qs.....
- resetting ECU
- SILENT EXHAUST
- INDIGLO GAUGES!!!!!!
- Mobil 1 weight...
- Yet another cooling problem
- dented door
- Your Thoughts
- Will the...
- Resetting Maintence Light in 94 Integra
- Idle is Too High!
- Clutch Pedal
- Honda hates Honda...?!!
- results from skunk2 manifold
- go with an intake or exhaust
- syncro
- make my car faster
- Will 2000 si wheels fit on a 1996 accord ex
- How much is a..........
- 90 intefra ECU question???
- Had An Accident
- my ECU
- Honda meet this sat!
- help! idel ?
- Noisy underhood intake
- My B20 is almost complete....
- 1st gear issues...
- ls/VTEC?
- why the hell would someone do....
- port and polish gains?
- suspension for 1.8L civic hatch????
- HELP!!!
- swap for 92 prelude si
- camber kit question
- NEED MOTOR TORQUE SPECS 4 - B16A.
- question...
- motor oil question...
- a/c question r12 to r13a
- Coilovers and other assorted questions...
- auto to stick AAAARRRGGGGG!!!!!!
- Fuel Gauge Dips when I accelerate...
- anybody got a clue about ignitions on 89 accord???
- AEM intake install
- turbo
- INjectors...
- clutch fit?
- More Torque!!
- rolling the fenders
- boost brain first...
- TUCKED!!!!
- CTR cams vs ITR cams
- jg-edelbrock header
- What next?
- Ignition question...
- Mr Self Destruct i need 2 no
- zc& d15?
- DOES ANYONE HAVE THE SPECS FOR A B16A?
- Rotor
- dose any 1
- I need 2 used exhaust valves D16 VTEC
- Need a vtech
- MY Civic...PICTURE
- Electric Load Detector ECU code 20?
- integra tranny swap....
- i need to know
- do u have to retorque crankshaft pulley bolt aft
- Whats the going rate for...
- Suspension for H22 civic hatch
- Reliability of a Hybrid
- B16A piston and rods in D16??
- carbon buildup
- Civic rear disc brake conversion
- JDM B18c1
- HELP!! Synthetic Oil Problem
- Help!!!
- question on guage cluster for civic
- 1997 Honda Accord VTEC--TRUST DC Sport Apexi et
- Slammed S2000!
- WOW!!! The cheapest and easiest mod!!!
- Installing Piston & rods?
- SOHCs running a dry 50-65 shot?
- LS w/itr pistons???
- Does anyone know???
- Manual tranny fluid
- speedometer goin nuts
- Fuel running rich
- B18C1 Dyno graphs
- Toda Pistons w/ Stroker Kit
- anybody else listen to the RSX in the commercials?
- vtec engagement point
- Question on intstalling a lip spoiler.
- Valve adjustment for civic
- valve adjust
- lookin for the dyno man
- aem
- Integra turbo
- RSX tranny on 5th gen prelude?
- Higher Compression
- JDM ITR 4-1 Header
- Question on Civic and Integra suspension.
- RSR exhaust!!!
- Cam Gears
- Need help installing a new tach!!
- SC B18C1 internals...
- Dyno Runs
- Using GSR rods for LS/VTEC
- Rear sway bar on EG hatch
- TURBO CIVIC
- Shifter/Shift Linkages.
- Spark plug broke inside cylinder head
- What does b16 powered 2nd Gen Rex go around Tampa?
- Technical Site of the month
- Horses
- rod/stroke ratio
- what do i need
- Idream of turbo..I mean geanie...doh!
- aftermarket intake
- Injen
- blocks and heads
- B18A/B crank on a B16 block
- motor help
- Review of OEM foglights...
- BILL
- Type-R Color Code???
- oops...
- Lindell
- SI-R
- Suspension
- Grooved Flywheel...
- gauge cluster swap?
- is anybody running Nitrous on a 2000 or newer GSR?
- dohc heads repost question please dont ban me
- How low should i go?
- How do you.....
- Advice???
- CF Hoods
- car audio websites?
- picking up this fellas.......
- Can a block with an ovalized sleeve be saved?
- TURBO GSR or LS?????
- Good for what?
- turbo problem
- Something grinds in third?
- dohc heads
- Gude headwork...
- Rebuilding a engine swap.
- What about 17 ADR DTM wheels silver w/ rubber?
- RSX aftermarket parts
- B16b engine
- 95civsi
- Engine swap places ???
- ex ecu
- ls tranny
- Honda Tuning Magazine
- loud vibration noise when in vtec
- 17 TSW VX1 chrome wheels for 93 Integra
- Seat removal
- Show me EF-9 Civic 88-91
- jrsc
- 99 civic ex....vtec?
- S.O.S.
- Venom 400
- hybrideg
- Help Clutch not disengaging
- Fuel Pressure
- dx to si part 2
- Is it wise to......
