PDA
View Full Version : Honda/Acura Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 [112] 113 114 115 116
  1. Oh Please ! ! !!
  2. INTAKE MAN. SWITCHOVER
  3. confused about crx swaps
  4. want to paint my car-need suggestions
  5. Best Clutch for Turbo Integras?
  6. Fuel Pumps
  7. 4000hp integra!
  8. I need an Engine Hoist This Weekend ! !
  9. rear disk brakes on CRX?
  10. question?
  11. turbo help!
  12. FIRST TIME USER WHATS UP
  13. No seriously...I want an engine for 87 civic
  14. cx tranny
  15. cant fit jack stands?
  16. painting rims?
  17. WTF
  18. Loud humming noise...
  19. cat cuestion
  20. SOHC camgear
  21. header?
  22. Valve lash settings
  23. ITR injector flow rate
  24. spark plugs
  25. pics of the teg
  26. replacing valve springs w/out pulling head?
  27. Engine Question
  28. differences between 9798 and 0001 b18c5
  29. Please help!!!!
  30. ECT sensor
  31. Thank goodness for tuning...
  32. new honda?
  33. Throttle body question...
  34. Cat sizing
  35. anyone interested?
  36. Need some help...
  37. Getting new tires...which ones should I get?
  38. Welding rear subframe..
  39. ls swap info
  40. Replacing spark plugs
  41. 94-97 Accord Auto to Manual Tranny swap
  42. Throttle body question....
  43. ? SOHC Vtec Head on DX Block ?
  44. INTEG ????S
  45. CAM GEAR ????S
  46. Someone refresh my memory??
  47. b16 a/c in crx
  48. Timing belt
  49. 2000 Civic front camber correction ?s
  50. Need help with D15 motor
  51. Prelude power steering removal/ Tranny cooler.
  52. B20 cuestion
  53. D15 help please
  54. Tie bar uninstall...
  55. what are the best upgrades for a gsr?
  56. Mounting 02 sensors
  57. Is this possible?
  58. JDM 4-1 header vs. dc jdm 4-1 header
  59. WTB92-00 SOHC V-TEC HEAD
  60. Portflow
  61. ls o2 sencer
  62. 3rd motor mount
  63. 17X8 wheels??? Help
  64. hasport a/c bracket?
  65. swap tech please help
  66. Tanabe Exhaust ?s
  67. cvic coupe rear bumpers...
  68. Axle problem...
  69. ecu?
  70. Question? 2000 LS in a 95 Civic DX
  71. balance and blueprinting
  72. Blown Motor(s)...
  73. crx sunroof
  74. Please Help!!!!!!!!!!
  75. Hmmmmm...Teg MC on an EX booster...
  76. D16->B16 crankpully ?
  77. Exhaust opinions please....
  78. LS bottom end ???s
  79. 86-89 Integra Ecu location?
  80. crx headlight bulb replacement
  81. NameThat Head**pic**
  82. an interesting link--
  83. Anyone hear about fidanza cam gears?
  84. ARP Head stud question
  85. Spoon Sports
  86. HELP!!! headstud problem
  87. type r timing
  88. Turbo Input
  89. b16 block swap
  90. 6 spd porshe boxter tranny and 1.8 ltr acura motor
  91. 98 Accord w/H22a update.
  92. Understeer - oversteer question
  93. JG CAMs
  94. injector swap???
  95. adjustable struts
  96. can anybody install springs??
  97. dohc vtec specs
  98. ?s involving toda cams.
  99. 88 Accord alternator removal
  100. How do i make the GSR back seats fit?
  101. Hondata
  102. transmission question
  103. rear strut bar
  104. Belt question
  105. JRSC on d16y8
  106. D15 on a D16
  107. How do you take out Factory Honda Cd Player???
  108. size of the h22 throttle body
  109. 50 shot?
  110. Interesting Secondary O2 sensor solution...
  111. door handles..
  112. new farrarie time...
  113. Anyone ever had Eibachs on a CRX?
  114. Type r cam differences
  115. 1.8ltr in 1.6ltr Civic LX
  116. 95 civic ball joints
  117. AEM EMS just incase anyone is intersted...
  118. shocks/struts?
  119. What to buy my rex?
  120. itr flywheel/ clutch
  121. what retainers to use?
  122. Shift linkage
  123. axles
  124. p28 program
  125. Replacing A/C belt
  126. Great article on engine resleeving
  127. fuel injector and distributor question
  128. transmissions
  129. best place to buy head gasket set
  130. Vortech SI
  131. PR-3 ECU CHIPPING.
  132. engine question
  133. Rear Sway Fitment Question
  134. Z6 head seals question
  135. Vietek
  136. I NEED FUEL REG AND GAUGE.
  137. D16Z7 ( vtec ) Question
  138. ecu chipping
  139. 88-91 b16 ecu
  140. Rim questions
  141. b17a EF swap a/c bracket needed?
  142. rack problem?
  143. motor mount
  144. mini-me?
  145. ls/vtec b16 rev limiter.
  146. b17a crx
  147. b17a crx
  148. crv 5-speeds
  149. flange help needed...
  150. b20 in CRX
  151. HELP! shiftlinkage removal
  152. Motor mount bolts questions ! !
  153. Advanced timing articles
  154. rev limit about 6000 after spending time at 7000 r
  155. Opps !!!! I fucked up Will it be OK?
  156. more CRX ???s
  157. Intake manifolds...again..
  158. master cylinder/power b.b.
  159. Gen 2 Integra. Diff between 90-91 and 92-93 cars.
  160. 92-96 prelude 5 lug conversion?
  161. 1987 CRX
  162. fast and the furious civic
  163. What can i get for my car?
  164. made my dx>si/hf wireing harness today
  165. Arp rod bolts torque specs
  166. Definitive source of 2002 Honda Engine info?
  167. How much does Curb Weight really matter?
  168. 1.6 SOHC VTEC Head on 1.5 SOHC NON-VTEC Block
  169. Prelude Shock Knock ARgH!!
  170. bad clutch??wtf?? help
  171. CAN THERE BE...
  172. caster
  173. wierd ass camber deal
  174. GSR Tranny
  175. LSVTEC........working now @a street corner near yo
  176. p72 doesnt see what the p13 does?
  177. Best Header ??** Hot Info Inside
  178. which is better?
  179. Web Sites
  180. top speed of 93 prelude question
  181. Clanking Question
  182. WHO IS THIS GUY..?
  183. WANTED
  184. LHT Swaps and warranties
  185. itr intake manifold on 00 si
  186. B18a or B16a throttle body?
  187. Torque
  188. help with factory lsd install on b18c tranny
  189. differnce between Acura Type R motor and Del Sol s
  190. CRX b16a power adders
  191. CRX questions
  192. Steering wheel problem
  193. skunk2 manifold on b18c in EF
  194. Main relay location 1990 Integra
  195. motor question
  196. CRX hf or si
  197. CRX ???s
  198. how to wire my o2 sensors
  199. CRX suspension quesion...
  200. HONDA SUPERCHARGER
  201. JRSC vs DRAG vs Rev Hard
  202. B20 DOHC valve spring compressor
  203. 9000rpm....
  204. GSR pistons in B16
  205. Help on Swapping Tranny...
  206. i need engine work done
  207. Need swap help
  208. dyno?
  209. honda
  210. What exactly is bogging?
  211. no honda
  212. rebuild with boost
  213. gsr injectors
  214. Heres A Link For Any Honda People Looking For A Mo
  215. Team Evil Dyno
  216. Idle problem on 92 civic
  217. Pressure Regs
  218. Codes
  219. Good camber kit
  220. VTEC question
  221. Vehicle Speed Sensor
  222. future of turbo honda
  223. Just got a new car!
  224. wires
  225. 89civic B16 to B18c
  226. headlights
  227. Springs
  228. wiring harness
  229. boost question
  230. integra seats
  231. Which clutch cable and bracket???
  232. O2 SENSOR
  233. poormans type R
  234. need rebuild info
  235. rebuild supplies
  236. CR-VTEC
  237. d16sprchrgd or b16a
  238. sohc vtech swap in a rex
  239. I hate u all
  240. V-TEC
  241. AWD civic
  242. d16 1/4 mile times
  243. ITR suspension on a 90 CRX si?
  244. CRX swap info?
  245. 92 prelude si parts?
  246. New Rubber
  247. hasport or hcp ?
  248. 86 crx si suspension
  249. well i get my tranny tommrrow
  250. Nitto Drag Radials
