- Do I need a camber kit?
- Why should I not use Crower?
- need camber correction and alignment asap.
- Del Sol intake manifolds
- fuel pressure setting?
- can i run turbo on stock b17a1??????
- CL People?
- todas+fuelpresure....
- inexpensive struts
- Getting coilovers-- need advice on which ones
- shifter bushings
- How does engine braking work?
- Vacuum in the cooling system
- will a vtec head fit a f22b2 block?
- JG Strut tower brace
- Help with a strut install.
- How much for a ITR...........
- NEW motorsport!!
- anti-fog
- hybrid over heating
- Does anyone have a breaker bar????
- Engine Code?
- vtec does not crossover untill 5800rpms
- fuel pressure regulator help!!!!!!
- head unit
- clutch
- Brakes gettin kinda soft....
- Difference between usdm b18c and jdm b18c
- camber kit??
- Question about H22A swap
- dis cap
- swapping gears..
- I Need Stiffer Springs !
- vehicle weights?
- Blasted shift linkage ??s again
- neuspeed short shifter threading
- any places that sell used turbos cheap that work?
- What is VAFC and how does it work
- oil pressure gauge
- Alignment shop????
- Camber kits????
- Clutch/flywheel install
- WHERE IS THE BEST...
- 94 DX dist. on a B16?
- Cam gears ITR Cams Apex`i V-AFC install and tune
- Opinions needed.
- coil-overs..
- Last pics before the install
- 89 civic engine swap
- why do vtec hondas smoke?? HELP?
- LS/VTEC again
- weird surges when driving
- Robster??
- venom 400...are they worth it???
- Cable tranny into 5g?
- Anything I should get before....
- wiring harness...
- Can you paint......
- fuel efficiency on b16a?
- D15/D16 Shifter Linkage
- Head rebuild
- F20C
- spring installed incorrectly ?????
- Putting a new cd player in 00 civicex will this a
- Alternator help!!
- dammm hondas
- fluctuating idle
- Civic problem!!
- whats wrong with my 89 hatch?
- Hondas MAP sensor......
- header alignment
- Motor head web site??
- Struts lowering a Vehicle????????
- rack and pinion boot
- 2.2 SOHC Vtec in a EG civic??
- head light/tail light
- ecu tps code
- break in questions
- type r camshafts
- Swap in the ol DX
- Je forged pistons compared to USDM ITR pistons?
- Pretreatment of new wheels?
- Whinning noise from tranny
- Brake swap review....
- bypass second o2 sensor???
- What does it take to make a B20/vtec?
- is ls/vtec motor good for turbo applications?
- Dart/Payn Aftermarket Blocks
- install of aftermarket auto shifter?
- spring compresor and strut install?
- Some interesting brake booster tid bits...
- Soch head desing
- Next thing to buy....
- - V-AFC -
- Question about B18C5 and CRX
- lighten fly wheel
- Throttle body Q
- H22A
- Honda ??s
- wuts the best way 2
- Pesky maint req light
- What am i in for?!
- Breaking News The OG Hybrid Board
- Interior question?
- Leather seats
- www.hondaswap.com
- Honda N1 Crank pulley
- Brake Hose
- Honda All-Motor forums?
- ecu or vtec controller
- 94-97 honda accord headlights..
- Anybody using 2 different brands of drop springs?
- HEADER QUES....
- chipping ecus
- is my clutch gone?
- Gude Cams...
- Throttlebodies for the accord?
- v tec controller installation
- CF hood for my sedan
- Wiring locations in tampa??
- hondata 2vs3
- HX wheels
- 97 ls obd1
- got fucked up
- balance?
- funny idle?
- CF Hood For 92-95 Hatch?
- Bseries trannys
- wireing question
- CTR slugs in B18C
- BRAKE LINES !?!
- starter????
- type r lug pattern?
- springs
- venom 400?????
- Brake Tech ?
- Apexi World Sport
- Endyn Blower?
- tranny prob....
- wtf!!!!!!!please help question!!!!!!!wtf
- crvtec or ls/vtec?
- 1.6 SOHC Vtec Engines
- Voltage
- Question...
- tire sizing????
- Window Regulater
- Need some warranty help
- A/C Idler Pulley...
- Need help bad...
- My lil bro just bought....
- Swaps into 96-00 civics
- tranny
- g-Force T/A Drag Radial
- Throttle bodies
- need motor baaad
- Advanced timing ?
- a/r ratio for turbine housing?
- Where can i buy used Acura parts?
- Cat dimensions?
- so i gutted my cat....meow....
- My luck day ) ITR 009 revived
- compression test
- EXHAUST QUES...
- Acura CL
- just got helms manual for b-day
- What do you run?
- height of a b16 head?
- Valve adjustment
- RC Injectors
- Field Vtec Controller
- Shes Alive ! ! ! !
- Check out my wonderfull wonder blue job...
- DX ECU....
- V-AFC v-tec engagement
- weight of 92 GSR wheels
- clutch
- GSR swap into 5th gen
- sumthins leekin???
- test pipe vs gutted cat
- CRX Headlight Bulb Size ????
- Wiring diagrams??
- ECU question!
- ATTN Mr. Self Destruct
- AEM calipers
- soliciting opinions on this itr intake cam article
- hybrid compression question
- Helms manual..
- msd ignition
- H22 into Integra?
- This is a Dumb ? but im knew so thats ok
- ITR Exhaust on 5G coupe/4dr
- 92-95 hb side skirts
- b16 head
- I need a d16 TB
- valve springs needed?
- clutch
- 93EX to Si upgade??
- Nice site for B20 buildup info
- Suspension
- Clutch Q
- injector upgrade
- Looking for Honda O2 Sensor
- TC question?
- Turbo Integra
- GSR radiator help....
- Exhaust size question?
- TB CABLE QUES...
- Fender related
- Turbo Si Preperation
- OK..at least tell me this.
- question about v-tec controllers
- Attn Kornizm-R and other Honda newbies Read Th
- header question?
- DSM 450cc injectors on turbo Si?
- v-tec head swap
- motor hight etc....
- http//www.hondaswap.com
- motor mount
- b18c5 & AT
- b18c5 & AT
- $ 4 turbo
- please help quick!!!!!
- help?!!!
- valve spring swaping????
- before I order the header.....
- clicking inside the block
- crx
- Shift linkage
- power windows
- big brake upgrade
- NOS+D16+?
- 00 Civic SI strut bar on EG?
- Need A-arm for civic....
- Teg Engine Swap Opinion??
- ctr cam gains
- I want one....
- Prelude 2.0 Si
- beating a gsr
- Recommended Mods
- Best damn Cam gears check it out
- Civic and Integra potential with turbo
- Yummy testicle pipe
- fuel pump flow rates
- cat flange jdm 4-1
- Blasted Headlights....(suggestion)
- saw an incredibel thing last night
- Mr. Self Destruct where art thou?
- got a b series cr question then looky here
- compression questions
