PDA
View Full Version : Honda/Acura Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 [110] 111 112 113 114 115 116
  1. what type of engine??
  2. z6 and y8 gasket thicknesses....
  3. Synchros for Integra....
  4. Question on B16a
  5. injectors
  6. gsr block/b16head? 1/4?
  7. Clutch Master Cylinder Go Bad?????
  8. North Tampa Custom . . .
  9. Question
  10. if you were gonan build a...
  11. `90 integra seats... please...
  12. LS... GSR...
  13. What tires to get for my Hx wheels?
  14. 3stage vtec head???
  15. 92-95 Hatchback
  16. Will this work for O2 sensor?
  17. Honda D-Series_
  18. 93b18 crank in crv block
  19. VAFC on an ITR
  20. b16a1 injector upgrade
  21. upper exhaust manifold gasket
  22. intake????
  23. which transmission?
  24. Ignition timing/cam timing and idle problems
  25. please help!!!!
  26. z6 vs y8
  27. prelude seats vs teg seats...
  28. what does a del sol si run in the 1/4 stock?
  29. timing problem...help
  30. where the hell is the .........
  31. Questions
  32. Is a b20 vtec reliable if built right?
  33. prelude injectors on a civic si?
  34. anyone have a timing light?
  35. how to take off wheel locks?
  36. Exhaust ?
  37. bounce
  38. where to get test pipe
  39. Should I do this with the build?
  40. Free Floating Wristpins
  41. D-series motor build up
  42. I hate installing a skunk2 on a gsr
  43. tranny problems
  44. Best exhaust system?
  45. will the charger fit?!?!
  46. High Compression ?
  47. 92-96 ludes...
  48. b16a3 throttle body
  49. WANTED 94 integra struts
  50. Hesitation/bucking
  51. hybrideg?????/
  52. ECU wiring
  53. tranmisson
  54. looking to buy d16z6 engine/tranny/ecu
  55. Honda Cranktool
  56. attn mr self destruct
  57. 97-up Prelude Question
  58. Is anyone willing to????
  59. need heaers install intructions
  60. GSR exhaust piping size???
  61. Two things i learned saturday...
  62. soch vtec
  63. exhaust piping size
  64. acura vin #s
  65. Anyone know to fix..........
  66. Attn Mr Self Destruct...
  67. How to fix?
  68. hybrideg?????
  69. 2000 dx hp capabilities
  70. Strange noise
  71. Best place to buy complete engine swaps
  72. alarm assistance
  73. Gs-r seats?
  74. P-28 on a Type R?
  75. Hybrid turbo kits
  76. BEST BRAKE PADS?
  77. 97 Honda Accord SE Headers?
  78. need speedometer HELP please
  79. d16z6 ecu question
  80. shave head on ls/vtec valve clearance???
  81. Anyone know ?
  82. Anyone know ?
  83. throttle body
  84. help me out with a survey
  85. Nice ECU Switch
  86. `99 Si exhaust... please help
  87. anybody with S1 tranny?
  88. ls/vtec impressions?
  89. mr self destruct
  90. what does a knock sensor look like???
  91. best place to powdercoat rims?
  92. how much horse power?
  93. Honda Group Buys
  94. please help
  95. crx big brakes....
  96. code
  97. Steering question.
  98. will vtec not work if?
  99. ls/vtec compression test. am i leaking???
  100. 2 quick ????s
  101. ZC info please
  102. JRSC
  103. Question on shaving my head...
  104. anyone willing to........and get paid?
  105. anyone know?
  106. over heating...
  107. Soon to build 1.8 need some help
  108. I F*&(@W(@)N CURBED A RIM - NEED HELP!!!!
  109. Over heating @ Idle
  110. jdm integra front end?
  111. Need R Springs
  112. MSD SCI-L
  113. Idle Demon
  114. i can fix your problem
  115. Motor out checklist
  116. putting GSR head on 91 integra
  117. port polish
  118. which yr b16 disc do i need????
  119. header + b16 + CRX
  120. john patrick says u may want a seat?
  121. ATTN JOHN tranny/clutch matchups
  122. HCP Mounts Vs HASport
  123. Painting an exhaust pipe
  124. zc into 90 honda dx ?
  125. zc into 90 honda zc need help
  126. Will this fit?
  127. Where to get head drilled?
  128. cam question
  129. dsm 450s on civic
  130. Monster Sport Type-Rs?
  131. main and rod bearings
  132. VTEC not working HELP
  133. 97 SOHC VTEC into 89 CRX
  134. props to North Tampa Customs...
  135. Valve Lash
  136. welding header?
  137. Del sol seats queston?
  138. VTEC on Head?
  139. Cracked exhaust manifold. Help!
  140. anyone got an extra battery?
  141. Anyone know a good transalxe shop and clutch
  142. Need new B pipe!
  143. GSR suspension on `92 CX
  144. rough shifting
  145. need a FPR
  146. Co2 wiring
  147. New honda parts cheap??
  148. 2002 civic ex motor
  149. where to get an alignment?
  150. carbon fiber hood
  151. fuckep up clutch/trans
  152. v-afc/ dyno tune
  153. ls tranny gearing vs b16a1
  154. turbo
  155. 4 lug stock honda rims 15 ?
  156. 91 prelude si tranny oil
  157. i need help
  158. Who can weld up my type-r oil pan ??? (Oil Return
  159. Tranny...EX vs Si
  160. gsr leather rear
  161. Need someone to do an Obd2 to Obd1 conversion!
  162. spark plug for ls/vtec
  163. LAF sensor
  164. Anyone know how to fix a SUNROOF?
  165. B16A2/B16A3 Drivers Side Engine Mounts
  166. 3rd gear...you guys got me thinkin...
  167. LS/Vtec question?
  168. valve spring compressor....
  169. Another compression calculator
  170. honda journal sizes?
  171. New shift linkage Sir
  172. Need an I-VTECH? Check out this auction
  173. to cat or not to cat...
  174. # 2 o2 sensor bypass?
  175. vtec question....
  176. phantom grip LSD
  177. help adjusting kyb gas shocks
  178. DRAG RACERS.. click here... POLL
  179. camber bolts
  180. Need B-series motor for sizing!!! Blown=Perfect!
  181. 2001 Type R headers on a 2000 GSR?
  182. wheel hop even with z10s.... WTF!?!?!
  183. grinding third i cant stand it anymore! help!!
  184. build me a test pipe.....
  185. hasport billet mounts
  186. I need help......
  187. Moisture in headlights
  188. FINALLY its started
  189. Im screwed!!!!
  190. B16 valve adjustment...
  191. Best header for a Type R?
  192. Civic Si Wheel Weight?
  193. Poor mans LSvtec...
  194. OBD1 VTEC Wiring
  195. OEM parts
  196. INSTALLATION SERVICES NEEDED...
  197. Headers?
  198. Wiring up VTEC on GSR Civic Swap
  199. how is part availability for the d16y7 engine in t
  200. Somebody please help me!
  201. ECU WIRING EXPERT...
  202. Stripped bolts...
  203. 89 LX motor into 89 CRX Si?
  204. ZC crx
  205. Seriously Considering ..........
  206. need some one to install
  207. Tuning vs. Flow
  208. wtf hondaswap.com
  209. Diameter
  210. Running Rich
  211. Oh.... !! The Carnage...
  212. Question
  213. Rocky Santa Cruz aka Onefastb18c
  214. Crower Sucks
  215. opinions
  216. Oil Pan Leak!!!
  217. intake manifold?
  218. All accord owners please respond!!!!
  219. price of the h22 or h23 installed in the accord
  220. cost of a underliner for the.....
  221. www.hondaswap.com
  222. Screeching with new belts?
  223. backfiring
  224. backfiring
  225. Anybody need a compression test done?
  226. attn Mr. Selfdestruct
  227. car is shaking when i hit boost?
  228. 00Si in a 5th gen ex HELP!
  229. d15b8 questions
  230. anyone have any slicks or drag radials i can borro
  231. skunk2 intake manifold install
  232. Need help finding....
  233. SWAP INFO?
  234. shop for interior?????
  235. Headers....
  236. help TB swap crazy ass idle
  237. Good lord its about time..
  238. does a vtech 1.6block off 92-95ex fit a 97 ex?
  239. KYB AGX or Konis on a civic
  240. correcting camber question
  241. d16 oil pressure sending unit
  242. Update on Crower problem... (pics)
  243. 1/4 mile times for 95 civic coupe with b18c1
  244. kill switch????
  245. need help with my first car! performance
  246. wheel question......
  247. seats for a 92 cx hatchback
  248. fly wheel
  249. 92-95 chassis codes
  250. Do I need a camber kit?
