- need help soon
- need torque specs for bolts on motor mounts
- Vortech
- d16a1 head on a 92-95 d series block?
- new swap. should I expect some sort of papers?
- Question about my hatchback
- B20 swap help
- no spark
- HELP! Spark plug wire order!
- Rota
- Ls/vtec head swap
- Have you ever had this problem?
- Clutch Master Cylinder LEaking Internally
- JOB
- Cost of an Ls swap into an 96 civic.
- obd2 to obd1
- air/fuel meter installation
- IT'S ALIVE...sort of, please read.
- quik ?
- where to find parts?
- Need estimated all-motor 1/4 mi. times
- i need a secondary O2 sensor A.S.A.P...someone..please help
- Just as I was about to buy some coilovers
- Can I put a DOHC ZC in my 93 Hatch
- Need Help With Overheating.
- Apexi Avc-R -vs- Greddy Profec-A which is better?
- sway bar questions...
- how will milling my head affect combustion???
- A preventive? how to?
- welding O2 sensors on 4-1?
- strange noise??
- A good shop to go to?
- Vavle adj.
- Compression test result & a question
- Anyone Know If the ITR Exhaust works on EG's ???
- O2 sensor plug wires
- MINI me questions
- putting on koni's
- Thermostat or no thermostat?
- Anyone know the weight of the mesh wheels ??
- Amps
- b16 or 18 ?
- 97 EX head on a 94 non-vtec block
- Best Turbo for a ls
- Does anyone know where I can get a B20Z?
- Thermal Coatings?
- 88 Accord won't start unless jumped
- ls vs. b16a ?!?!?!
- dx vx weight difference
- Diodes ?
- ??? about push starting a car
- ac bracket experiences
- Neil!
- ROD BEARINGS HELP?
- B16A2(Stock) w/zex...what to do next
- strut and tie bars
- DX to Si swap.. Wont Stop?
- ECU question
- phantom grip
- your opinion on pully's
- wiring harness for LS vtec
- Need troubleshooting help....
- ODB0 - ODB1 wiring and ECU pinouts
- Reservoir Covers
- D-Series Parts?
- EK to EG skirt question
- zc sohc
- Interchangeable ?
- improving timing to get hores
- Need part or help fast>>>
- CEL #6 Engine coolant Temp circuit
- 4.40 vs 4.785*
- b16a shipping arrival
- CV axels, B-series into 84-87 Civic/CRX
- Good junkyards to find acura parts
- Lug nut question?
- Supercharger, Turbo availability ?
- what do you think...........
- Engine Codes
- WTB: 95 Civic Si coupe BIGMOUTH FB & SPRINGS
- What is this?
- non-progressive springs for a crx
- NEX coilovers
- dual piont to 4 point wiring...swaping a intake need some in
- difference between vafc and safc
- Why you should never mess with cam gears while engine is on!
- vtec wiring????
- mounting 310 injectors on ITR manifold
- How do you you take off the silver bezel ?!?!?!?
- brake pads
- Timing belt tensioner
- idle adjustment
- What does this come out of ?
- jdm itr header
- I need P2T ecu pinouts...
- compatability ????? please help
- Radiator swap
- Car wont start!
- car isnt drop 2.5???
- Were to buy?
- CRX HUB ??????????
- Best bet ofr daily driven N/A ECu
- Rear Disc Conversion
- Front lip question
- Buddy Club Racing Spec Computer
- b16 tranny removal help
- Swap Question??
- crv into a civic
- Radiator Issues in a 92 Hatch
- car won't start
- Cams
- What is a Hatch STD? Honda not sexually transmitted disease
- 90 Hatch STD wired to 88 Si ecu?
- b18c in 00 hatchback
- Best cams to use with Nos on a LS/VTEC?
- Gear question.
- what happened here (pics)
- Just lowered my car...
- O2 Sensor Engine Code thrown
- 88 crx timing belt
- rev limiter
- Where to get work done?
- radiator problem
- LS/VTEC HELP
- 84 Civic, help...
- turbo install?
- Best D-series block?
- More problems with room mates 91 accord
- Radiator fan doesnt come on?
- CRX/Hatchback parts
- mini me swap???
- how to get blockguard out?
- running rich with a turbo?
- H23 to an H22 swap
- This is weird
- Lugnuts
- boost on my 10.8:1 CR???
- Turbo manifold?
- Axels and Halfshaft??????
- apexi world sport questions...
- B16a.... will it fit on my tranny?
- Are they the same?
- error code: 91
- Error code 22 on Integra GSR!
- Spoon Engines?
- Honda Tuning (No not the mag.)
- Thanks John, Hondata is so cool....
- HX rims fit on GSR brakes??
- Integra Brakes on a civic del sol
- RUN WHAT YOU BRUNG THIS SUNDAY
- my idle is acting up
- Best way to spend $3,000 on an EX and get close to 200HP
- my front sway bar doesnt fit...
- thermostat?
- cams making engine louder????
- MiniMe swap.....
- whats a good price for a 94 vx hatch
- stroker kits for the b16a
- wiring conversion
- IS IT LAGIT
- AEM Air Bypass Valve
- ECU codes
- Car won't start...
- Running too rich
- Installing Springs...- Probelm!
- Weird ass engine problem......
- heater core leaking...
- Still want to convert my auto to a standard..
- B20B or B20Z
- Socketing an ECU...
- denso??
- How can i convert my CRX hf auto --> 5-Speed
- Nitrous on a Built B18C
- WRECKED
- Throw-out bearing?
- ls tegra wirring???
- h22a sawp
- CTR JDM Pistions
- axle problems...
- OBD2/OBD1 conversion harness
- Favor Needed: B-series/D-series AC mount
- egr question
- Headlight
- The Shifter Bearing?
- GSR tranny help
- Skunk2 Cam Stage II
- 92 Hatchback Coils n shocks
- dc5 r into ek civic
- Spark plugs?¿
- Need help.. 3 codes.
- need some help on my AEM cam gear (tuning the fucker)
- CRX B20
- Question about air filter
- B20 Performance?
- So Will The Hondas Be Represented At The Track Day ?
- car just stopped running
- Tokicos
- sohc vtec to dohc vtec wiring harness question
- What's so great about a B17?
- INJURURY ON INTEGRA FRONT FENDER< HELP
- Integra short shifter
- check engine light.. NOOOO
- Suspension Techniques Rear Sway bar
- Axle problem
- rear disc installer
- LS/vtec - Pros and Cons
- rear rotors...
- Del sol civic
- Tires
- My pulleys
- crx swap help
- Slicks for my 1990 Civic
- CRX STAG
- For everyone who has a gsr short shifter.....
- Coolant flush probs need help
- AC or no AC?
- ??? 88 crx si block to SOHC vtec head ???
- 2000 prelude error code plug???
- type r exhaust...92dx hatchback
- I need opinions ...Please!
- D15B7
- Motor Swap?
- Check Engine Light?
- HX rim weight?
- syncros
- ??? Tire Rubbing ???
- what to expect
- B-16a head swap
- gsr cams and header into my hatch?
- Best Hi Flow Cat
- CRX troubles
- Engine lift?
- I need someones help
- turbo install?!?!
- Shocks w/ a 1.5" drop
- H&R sport vs. Neuspeed sport springs
- Decisions, Decisions? LS + Turbo or GSR N/A???
- Integra Coil-Overs on eg civic ?
- Tripping Cooling Fan ??
- JDM GSR?
- Would this fit?
- JDM GSR MOTOR??
- Non OBD to OBD 1
- B16a+itr pistons
- CRX HF idling and stalling
- Whats the best ..
- question about tranny swap?
- broke a wheel stud
- any info on jdmclub. com
- Ferman Acura
