PDA
View Full Version : Honda/Acura Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 [105] 106 107 108 109 110 111 112 113 114 115 116
  1. Any place cheaper than majestic honda to buy parts online?
  2. Integra 4wheel disc changed to 5 lug ?
  3. Noise Problems....HELP!!!
  4. which would you do
  5. **can someone help me, Please**
  6. Replacing Integra power antenna
  7. 90 crx si tranny+ clutch ? can i use DX AXELS?
  8. VTEC not engaging properly...
  9. Hondata tuning for B16A
  10. Need a good machine shop for head resurfacing
  11. Check engine light from hell...
  12. Dec 13th, Club 1320 @ Bradenton
  13. Replacing clutch master cylinder
  14. Prelude tech
  15. Intake manifold vacume leak
  16. radiator for turbo gsr in 93 cx hatch?
  17. Championship white pearl ITR paint code?
  18. What would you...
  19. LS head bolts...rebuild??
  20. what wire for A/F gauge?
  21. Break in Question
  22. homemade mounts!!!
  23. Hondata S100 or APEX-I V-AFC?
  24. 16a probs
  25. **Question**, JDM style license plates?
  26. stupid question...short shifter
  27. Pics of my new intercooler
  28. d series turbo
  29. Honda Audio Question
  30. **one question**
  31. aftermarket suspension?
  32. D series deck question...
  33. is it just me
  34. *****Port+Polish/Injector Flow Rates*****
  35. Fuel pump wont turn on
  36. quick tech ??
  37. piston question
  38. EG door panels....Help!
  39. bottom end question
  40. Skunk2 Intake manifold install??
  41. oil pan wont seal!!!!!!!!!!!
  42. CRX PARTS NEEDED HELP
  43. How much should i sell this for
  44. removing head bolts??
  45. good prices
  46. places to get..
  47. GSR SEATS in a 89 hatch??????
  48. UPDATE......dead ls motor!!
  49. electric load detector
  50. LSt progress so far
  51. Need a stock header and muffler
  52. GSR help please?!?!?!
  53. NEED HELP WITH B16 SWAP!!!!!!!!
  54. Springs on 02 civic
  55. car shaking?
  56. Rolling fenders?
  57. b16a crx swap help...
  58. HELP!!!!!!ASAP
  59. LS power
  60. will this work?
  61. integra lca bushing question
  62. 2002 Civic Engine Swap
  63. 95 ez is it fast?
  64. i need a hand modding my RSX
  65. Crx with B16
  66. swap..
  67. running super rich...
  68. idle speed
  69. quick question
  70. Fluid on head
  71. donni from racerelated on whends night
  72. no comradery amongst honda owners?
  73. dohc valve cover cut
  74. LS/VTEC????
  75. can someone identify this problem???????
  76. ACT Clutch
  77. Tranny Issues
  78. a/f guage questions
  79. Desperetely needing a turbo manifold!!!!
  80. need help
  81. car is throwing code 71,72,73,74
  82. GSR Brakes
  83. 88 crx tech questions...
  84. car troubles please help
  85. CR-Vtec
  86. Skunk2 Intake vs. Stock
  87. sleeving a block
  88. Curious
  89. Engine Managment question
  90. Throwout bearing...
  91. need a phone number
  92. Del sol automatic performance options.
  93. it won't fire up
  94. I'm here if you need me, don't be afraid to ask.
  95. tip on preventing front lip from being stolen
  96. crx? yes or no i dont know shit
  97. Short Shifter for car or for motor and linkage in car???
  98. question
  99. ram air civic
  100. Ground Controls
  101. i was wondering
  102. what do i need
  103. warped block....
  104. FDM integra front end
  105. Check Engine Light
  106. CM stage 3
  107. Maybe you can solve my problem???
  108. looking for Stepan Jamon
  109. H22A mod Help
  110. NX install
  111. stuff i need
  112. integra ls stock results....information
  113. need to know soon
  114. Plugs and Plug Wires
  115. CX =SI 92-95 wiring problem
  116. yellow JDM ITR Recaros!!
  117. L3 (jdm)lsd into a z6 tranny???
  118. MUGEN HEADER
  119. Integra front end conversion!
  120. plugs and plug wires
  121. distributor
  122. Turbo
  123. turbo tips
  124. 5th gear popping out
  125. headers, or cams?
  126. B20 VS LS
  127. how much...
  128. manifold swappage
  129. Zero 1 Racing
  130. RSX modding help
  131. ****LS turbo****
  132. Car wont start..
  133. CRX Climate Control Unit
  134. BOV battle
  135. sites for turbo parts
  136. Aftermarket SOHC intake manifolds?
  137. error codes
  138. What size Slicks Will Fit on my car....
  139. Teg cluster in an EG
  140. crx header question
  141. Dash Question
  142. For all you sohc fans
  143. What H.I.D. conversion is the best out on the market?
  144. 92 integra LS MOUNTS DONT LAST
  145. BUSHINGS
  146. most bang for my buck-opinions wanted
  147. NEED HELP- NO SPARK
  148. can a R intake manifold fit on a 1.8 LS head
  149. crank pulley tool
  150. good site with good prices
  151. CEL 15?!?!?!?!
  152. Want to find: 79-83 Honda Civic
  153. B20 TB
  154. a question
  155. ***MORE LS VTEC***
  156. 97'-01' Prelude
  157. LS-t parts list do far
  158. similar to the check engine light post but not
  159. check engine light???????
  160. anyone know of a good machine shop???
  161. Rubbing?? 205/50/15?
  162. Choice of pistons
  163. y8 intake
  164. Drag 3 instructions?
  165. '91 crx si or '95 civic si distributor
  166. 3 questions
  167. OBD0 or OBD1
  168. 5th gen prelude error code plug
  169. engine performance book
  170. profec b/wastegate question
  171. b18b turbo or B16a2 turbo?
  172. LS VTEC ?
  173. Help: B series oil pans interchangable?
  174. $925 to resurface my head sheesh..anywhere else...
  175. LS-t build up
  176. Hondata
  177. Auto to stick?
  178. B20 questions.
  179. B20 + Nawzzzz
  180. Motor swap help
  181. ITR intake manifold on GSR motor?? How Do I Do It??? HELP!!!
  182. Integra exhaust on 92-95 civics
  183. help plz: ls/vtec question
  184. A20A1 / B20A3
  185. please look boost & n20 junkies
  186. Help: Shitty Idle
  187. Looking to settle a bet! Acura vs. Honda
  188. 97 Civic EX motor into 89 Dx Civic?
  189. 93 teg fan cooked by headers?
  190. Integra suspension under 5g civic
  191. all motor d16
  192. energy suspension bushings installed?
  193. gut my cat?
  194. SOHC's fast as DOHC
  195. quick question
  196. starting with a lude
  197. HELP
  198. ABS?
  199. 98 h22 in a 94 Prelude
  200. crx mini me swap?
  201. ECU RECHIPPING HELP
  202. I need a T-66 bb turbo, where do I go HELP!!
  203. Spring Question
  204. best place to have fender painted
  205. Quick question...
  206. ecu identification
  207. Need wiring diagram * fields vtec controller into obd1 READ
  208. Milled cylinder head ............................
  209. What turbo to use on Ls?
  210. Check Engine Light Problem driving me nutz!! Check it....
  211. Cam Gear question
  212. YET ANOTHER.... Silly question...
  213. Quick guestimation....
  214. Brake Upgrades
  215. any of those fast hondas going to your track day
  216. Okay I fixed one problem, here comes another
  217. Good places to get my sawblades polished???
  218. ef disk brake conversion
  219. Civic wing for sale
  220. 97up Prelude wide bodykit
  221. GSR SWAY BAR question
  222. Which motor mounts do I use for a d16y7 motor in 89 hatch?
  223. beat header for my D16z6???
  224. Any one running Hasports latest gen. billet mounts in 88-91?
  225. p75 rechipped for vtec?
  226. the finished N20 project
  227. Ecu Code Probs
  228. Building another SOHC
  229. Need some help deciding...
  230. battery keeps dying,
  231. FIelds VTEC Controller and Air/Fuel mixture tuning .....
  232. Help idle problem
  233. Where can i get my koni (red) shocks adjusted...
  234. ??? about swaping engines in my Civics
  235. settings for the vafc and cam gears on a prelude...........
  236. Help Me Decide. What should I do????
  237. Hard question.
  238. Possible Vacuum leak?
  239. lsvtec
  240. adjusting vavles on the teg, and a question... plz help
  241. Clean B16A Engine Pictures from Jay Whitley's Garage
  242. what the hell is a code 10????????
  243. b18b internals in b16 block
  244. ecu selection
  245. Crower Issues
  246. A real stupid question...
  247. need help picking motor to build for 98 Civic DX
  248. Stupid question...?
  249. Apexi or Field
  250. motor mounts
