PDA
View Full Version : Honda/Acura Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 [104] 105 106 107 108 109 110 111 112 113 114 115 116
  1. Who had the 12:1 compression pistons for Sale???????????
  2. need suggestions/ v-tech or turbo?
  3. need yet onother opinion
  4. I'm torn.. need your opinion please
  5. it just so dayum
  6. H22a/Accord O2 Sensor Problem NEED IDEAS!!!!
  7. 94 integra armrest/ 92 civcHB?
  8. Keyless Remote
  9. What Ecu for gsr w/itr mani?
  10. gsr cluster??
  11. B18B into 90 auto questions.
  12. help with wiring
  13. help with wiring
  14. TIRES???!!!
  15. Prelude bolt pattern
  16. Need everyone's thoughts
  17. My new "project"...
  18. intermediate shafts, same part for all gsr's?
  19. electronic dash
  20. bolt ons
  21. anyone has an intermediate shaft (for a 95 b18c1)
  22. PLEASE HELP ME (LS-VTEC)
  23. Fuel pump
  24. Hi Flo Cat
  25. EF Replacement Crossmembers
  26. Forum sort order fixed and finalized.
  27. I will never recommend another DRAG kit again!
  28. A word of caution when buying your OEM oil filters
  29. BACK TTT
  30. new body kit for the crx bad ass
  31. can you help me out
  32. just looking for answers, not criticism
  33. post whore welcome
  34. FOG LIGHT INSTALL
  35. how to tell difference between LS and VtEC oil pumps???
  36. ecu
  37. What are some good..
  38. Carsound cat took a dump...
  39. LHT Performance
  40. JDM itr ecu vs. USDM itr ecu
  41. What will the HP and TQ be with ls vtec
  42. Help! Idle drops when brake.....
  43. aftermarket retainers and springs d series
  44. Yellow JDM look bulbs?
  45. type r ecu
  46. tranny gremlins
  47. custom catback
  48. anyone ever heard of.....
  49. afc vtec question
  50. Fuel Gauge Problem
  51. tb and intake
  52. GSr tech info...
  53. GSR motor in 96 civic coupe....Which intake
  54. just a ?
  55. Where to get a swap?
  56. 1320
  57. Rod question
  58. distributor wiring question
  59. d16 throttle body question...
  60. speakers
  61. baddest turbo honda in the world
  62. Should i go with a 190lph or 255 lph on my NA prelude
  63. Leak down test....
  64. LS vtec question?
  65. Vss Sensor 94 H22.... Suggestions??
  66. JDM ITR Header Install
  67. Back Fire
  68. Holes? if remove stock H emblem?
  69. Question on Lude Struts
  70. Which ECU will work
  71. HF manifold to turbo manifold???
  72. knock sensor?
  73. How can you tell when fuel pump starts to go?...
  74. type r pistons difference????
  75. HELP ME!!!!!
  76. compression/hp?
  77. How to ...
  78. 30 Runs For $30 ?
  79. Distributor question
  80. USED PISTONS AND RODS????? (new question)
  81. LSD
  82. chip installation gone bad so i think
  83. F-Max Turbo System on 94 Integra LS/RS/GS
  84. Thermoswitch???
  85. Guages went dead........
  86. motor question
  87. I NEED INFO ON INSTALLING GAUGES ON MY TYPE R 97'
  88. crx dx weight
  89. something wrong
  90. D16Z6/Y8 Rods
  91. Does Anyone Here Have a place for Stock Parts????
  92. Water leak
  93. what should i fill my radiator with....
  94. what is needed for a 96 b18c1 swapped into a 2k civic ex
  95. when does the V-tecH kick in?
  96. tranny case damage?
  97. b16intocivic
  98. Oil
  99. TB Sensor Question..... H22A????????????????????????
  100. question
  101. Welded Mounts
  102. Mini-Me compression...
  103. Thinner HeadGasket for SOHC?
  104. CMR???
  105. throttle body...d16y8 or b16
  106. swapped motor idels all crazy, help!!!!
  107. type r intake mani
  108. Help
  109. Flywheel ?
  110. ENGINE MANAGEMENT
  111. Fluctuating idle suks
  112. In for the last time... H22/Rex
  113. Salvage yards in the Tampa/Orlando area?
  114. swap shops in st pete area-tampa
  115. Build up stock motor....?
  116. i need a machanic
  117. GSR Brake Installation on Civic Q and A
  118. sohc vs. dohc fuel pump
  119. crankcase breather box on B18b?
  120. place to fix intercooler?
  121. looking for a good price on...
  122. Quesitons about H22a into 5g Integra.
  123. engine light on a odessey
  124. vtec head
  125. main bearing compatability
  126. Clutch Pressure
  127. what crank?
  128. Eagle Rods
  129. b16a head on a b18c1 block?
  130. Head tapping!!
  131. ADDING a 2nd battery??
  132. Changing head unit ?
  133. leaking B16......?
  134. RED LINE AT 9
  135. Anyone know ECU pin out on a 89 CrxSi??
  136. phantom grip
  137. 3rd gen gsr head+b16a3 block=? HP
  138. anyone know of a nationaly based parts autosalvage place?
  139. I Need Help!!!!!!!!!!!!!
  140. new fogger and pills
  141. DSM injectors install...
  142. B16 block
  143. OEM honda rings with JE pistons?
  144. how to tell year of block
  145. Car isnt starting(crx B16) crapy christmas present
  146. little exhuast issue here.....could really use some help
  147. coil over help
  148. Fuel Regulator Question
  149. making a D turbo manifold???
  150. engine VIN # location????
  151. 2 things
  152. best clutch?
  153. do this look good, bad. black hood?????
  154. speed governor
  155. which clutch
  156. *URGENT* Need part today!
  157. head gaskets?
  158. Big problems need help!
  159. are u this bord\go here
  160. HF BLOCK/DX HEAD WHAT COMPRESSION?????
  161. engine bolts?
  162. From the "More harm than good" files :(
  163. sohc turbo or gsr vtec/50shot
  164. double clutching
  165. Machining 94+ LS rods to fit D series...
  166. few simple yes or no questions b series
  167. Speedometer Jumping all over the place
  168. H22a ECU
  169. 5th gen prelude timing
  170. what is the CR??
  171. valves
  172. Honda Merry Xmas Wish to All
  173. Quaife LSD for D series.
  174. HELP PLEASE!
  175. Yes another noob question...
  176. approaching 60k on my GSR
  177. lost motion sensor help...
  178. What do you think this car is worth???
  179. LSD Question HELP!!!
  180. Crank Bearing Help!!!!!!!
  181. B16A2 question.
  182. ls tranny on a b16 block???
  183. test pipe
  184. INSURANCE
  185. spray on LS?
  186. motor mount question
  187. question about my zc. i could use ur help
  188. b20 swap problems... car will not pass 2500 RPM
  189. HONDA CIVIC PARTS....AND RARE HOOD
  190. VIN NUMBERS/MOTOR NUMBERS-
  191. TYPE R TRANNY
  192. Project C-ReX Phase 2 Complete! Pics!
  193. Car rpms seem to surge at stop
  194. streetable c/r for b20 vtec?
  195. What's my compression ratio?
  196. another hard one
  197. Apprentice
  198. mini me problem
  199. HONDA CIVIC PARTS....AND RARE HOOD
  200. new here and just looking for some help
  201. 9:1 JE pistons for SI's = what CR in a GSR?
  202. vtec not working ???
  203. in need of opinions
  204. What do I use to protect...
  205. tires/traction question???????????????
  206. need answer asap
  207. anyone ever painted there headlights?
  208. heres a hard one for all of yall
  209. custom cold air intake
  210. Shot in the dark
  211. q. panel
  212. climate control
  213. Welcome back to...
  214. i donno ppl
  215. B16 or B18???????
  216. Couple probs with 89 Integra
  217. good cheep tire's????
  218. Need info about replacing timing belt and H20 pump
  219. b16a2 or b18 long block
  220. Overheating
  221. PR3 ECU buzzzz between 4.7-5krpm???
  222. heres a hard one for ya
  223. Exhaust Piping Question
  224. Flood Damage to Engine *UPDATE*...Please Help!
  225. IT RUNS AGAIN!
  226. what tranny?
  227. headbolts(pain in the ass)
  228. CV axel question
  229. Tach Instal?
  230. speaker size for integra??
  231. ok need some swap tech help
  232. MIni mE in 88-91
  233. good lsvtec
  234. GSR swap in EK
  235. b16a1
  236. Need someone with some tranny knowledge
  237. Help! with brakes
  238. do you know anyone
  239. Help changing Crank oil seal
  240. a/c dont work. where do i start????
  241. any local place....
  242. Seats
  243. Alignment
  244. LS in a 89 hatch Q/M question?
  245. Check Engine Light Wont Go Off HELP!!
  246. HF vs SI
  247. Prelude Springs
  248. piston & rod setup ?????
  249. PRELUDE OWNERS!!
  250. *** Car show FREE ENTRY!!!***
