View Full Version : Honda/Acura Tech
- AEM ByPass Valve????
- Vtec problems..
- lots of b16 help needed (w/paragraphs)
- injectors
- WTB: Sohc Specialist
- tranny
- b16 manifold
- more tq
- quick question
- reading an a/f gauge
- lotta help needed b16
- Skunk2 P28 Questions???
- Rice Info
- What Starter Do I US???????????
- skunk2 cam gear question
- slush box problem
- sohc swap
- what are
- Looking for JDM Motor Source
- JET chip
- New 3rd gear
- Chipped ECU ?
- wide gears
- valve? on manifold
- Theoretical F20 crx
- loewr control arm bushing
- b16a1 alternator
- ITR Intake Manifold
- tranny puzzle
- I need more power from a single cam! how?
- Civic/Crx DX Wiring !HELP! URGENT!
- LS Turbo??
- Tires
- GSR Tranny on B20?
- LS Turbo's
- Cuz Im bored....
- b16a xsi
- Intake Air Bypass Control Solinoid Valve
- Ls Tranny Bolt Size??
- compreshion
- Replacing In Tank Fuel Pump
- crank balancing
- quick question
- idle air control????
- ls valve adjustment?
- Need Wiring Help!!!!!!!
- Project GS (Go Slow)
- corey
- tranny
- my engine took a drink
- measurements!!!
- engine swap
- timing belt????
- How to install
- computer?
- need help to swap out motor
- timing belt tensioner
- Acura Vigor
- Cel 2
- Best cold air intake
- crx dash compatibility...
- bleeder bolt for coolant????
- b16a crap
- b16a crap
- auto to manual tranny
- All motor LS, in LS
- rebuilt head
- AWD Civic kit
- Good Sites For 1st Gen Swap Info!
- gsr rear seats into 95 hatch
- hopefully difficult question
- LOUD Valve Tap
- 94-01 gsr problems?
- Clutch alignment tool?
- shops????
- hood pins
- stroked h22
- B18a or B18b ???
- which shift linkage?????
- Help h22 swap
- high idle
- Who is Kenji???
- need help asap!!!
- need help asap!!!
- Motegi on a civic ?
- Valve Spring Compressor
- auto to 5speed on 91 teg
- automatic tranny install...question
- SoL Swap
- Cluster Question?
- b16a swap help
- Any advantage to slightly larger dia. tires in front..say 215/45 F and 215/40 R ??
- Colder spark plug #??
- Redline Tranny fluid
- ?CARBON FIBER HOOD? 90 civic?
- Gotta Question for a 1990 acura legend coupe
- Transmission
- h22 rods vs. h23 rods
- radiotor??
- Ecu question
- Does anyone have a complete gsr intake mani?
- Crx HF vs. Crx Si, whats the main differences?
- h23 engine swap
- v-tec doesn't work????
- anyone have a Sunroof relay CRXSi?
- ITR Clutch FS
- Help!witch way for the block guard
- Hoods
- building
- open header?
- ITR pistons on LS Eagle rods?
- Oil pump gear
- crap
- Fuel System (ls-vtec)
- Iat
- For those that dont read free 4 all
- honda/acura turbo kits!!!
- Temp not working??
- *shrug* P28/obd1 issues?
- LS Head bolts oR b16 Or GSR
- crx hydro tranny?
- del sol seats in a crx
- B16A2 in EG, how to hook up A/C..help~
- CRX JDM front end
- ls intake cam install?????
- HELP PLEASE!!!...OVERHEATING PROB!!
- ex oil pump or si
- lowering 99 teg need help!
- prelude question
- h22 in a del sol
- Weird Idle
- SCS / MIL 94' Lude problem??
- LS/Vtec Questions??
- specs on a b20
- Door question??
- HELP! need valve spring compressor, asap!
- 88 Crx tranny swip swap
- F22b question
- quick question
- Anyone know which vaccums are "Not" Needed on a Lu
- Nees Assistance reading codes from a 94 H22A??? 6:37 PM 2/4/
- S1 GEAR RATIOS???
- P28 or not to P28.
- swap is done.. but chck engn light comes on then off, then
- where to get tapped???
- So fresh so clean
- what radiator hose do I need?
- any website on how to replace 02 sensor?
- tranny help
- Question about Power Steering
- Help W/Wiring???
- Single layer head gasket?
- Need help Identifing Wires on 89 CrxSi (Inj. Resistor)
- BODY SHOP
- Lude Question????
- power steering pump for 2kcivic with a b18c
- quick crx question
- FOR ALL OF YOU WITH THAT ANNOYING ,LOOPING,IRATIC IDLE
- where is the CYP Sensor (Cylinder) on a b16a
- ecu throwing codes
- Accord 2.2 Non-VTEC problems
- AEM pullies on Accord
- NEED HELP W/SENSORS
- What exactly IS final drive?
- best year hatchback to go
- can i hook up
- ACL Bearings
- C&R and SPAL
- super or turbo
- CAM GEAR DEGREE NUMBERS ON Y8VTEC/CRX SI 90 BOTTOM END
- taking apart hatchback
- will an adjustable FPR help me?
- 3rd gen Integra motor woes, help!!
- How do know you when your TPS has gone bad?
- crx si front lip?
- KENJI'S EMAIL ADDRESS????????
- OEM spray paint....
- Integra question
- -Need A Paint Job-
- NEED TO SEE THIS SITE FOR SWAPS!!
- Pressing Ball joints
- TRANNY HELP
- ls wiring harness to crx
- what should a b18 oil pressure be
- CRV seats?
- LS swap into an EG
- Anyone Bought from 92cxhatch
- need 84 crx head i think i bent valves.
- HELP Need good shop
- All right heres a hard one!
- some wierd issues
- H22a ECU
- check engine light is on, throwing out code 41, what is it??
- PLEASE HELP ME IMPORTANT !!!!!!!!
- ??? Integra intake question ???
- Mugen PR3 Chip
- ZC turbo
- Fuel pressure
- FlashOptions
- b16a2 in 93 si H/B help please
- h22a
- DASH SWAP > 90-91 dash into 88-89 CRX Si
- del Sol CEL
- CONVERTING MY CARB 1ST GEN REX TO FI??
- b series intake manifolds
- complete integra swap
- Are any of you going to the TR track day?
- LS Cam Question?? Lookin for some Input
- Info for b18a1.........
- Question about Skunk2 manifold changover
- did alittle research
- nitrous opinions
- ZC engine w/b16 head?
- Short Shifter Ques
- ls motor knocking??!!HELP!!
- 95 integra ls vtec swap help!!!!!!!!!!!!!
- orlando update
- OBD1 Wiring Question.....
- Can anyone explain Pro/Cons of a ZEX Kit???????
- Toda's camgears
- stuck in park, need help....
- Polished rod pictures
- back in the game!
- Piston ring install
- Where do you guys get your Naaaawz filled?
- idiot trying to swap stock 95 civic for ls
- Car over heating... at least it's telling me so...
- VALVE STEM SIZE?? are b and d series the same?
- Tach signal wire on b16a1??
- What program does everyone use to monitor There Ludes?
- What colors main and rod bearings do i need for ls motor???
- 5th gen civ owners
- BODY SHOP
- Bseries swap, A/C install question?????
- ITR ?'s
- main bearings colors for ls motor????
- Teg to crx brakes?
- #2 ls rod????
- b18a1 or b18c5
- Car runs like shit....
- Need to get power windows fixed
- Cooling fan
- anybody want to cut me a deal?
- ITR head swap on a 93 ls block?
- lht
- Questions.....
