- Help please I have a question!
- Fuel question
- coilover problem (grrrr...)
- cv joint problem
- B18a in CRX ? Whats it run ?
- help quick please!
- wanna swap but keep automatic
- Giving up on a B16 SIR G1
- Are all 92-95 Civic splash guards the same? Hitting the junkyard in the morning.
- obd2a and obd2b question...
- CONVERT MY DX TO Si PLZ!!!!
- im only happy when it rains!
- shop questions
- knock sensor question??
- nos on a b15a??????
- fuel press d16y8
- b16 in 98-2000 integra????????
- which intake manifold is better?
- Idle drops then stalls...
- Coolant hoses compressing when motor is not running. Pic inside!
- HELP!!! Code 54 on EK civic with B18c1
- valve ??s
- B16 ARP rod bolts... which ones??
- skunk 2 intake mani group buy
- Injectors
- nitrous
- erratic idle.
- good machine shop
- A New Civic you've GOT to see
- install ?'s
- does anyone have seats laying around?
- I h8 my car. SAFC problems...
- hondata questions.....
- How much is the most to spend?
- b16a Sir2 in 90-93 teg
- need name of a shop in st. pete
- Anyone have access to a GSR Helms electrical manual?
- B16a1 Axels???
- 90-93 teg cluster
- honda/acura meetup date poll
- Oil Problem
- Installing V-AFC
- wow! adjusting the fpr..
- Question about motor tanny combonation
- door pilar??
- still looking
- which plugs for zex?
- which rims on my EJ6
- delsol si heads
- queston about tranny
- where to have shocks installed
- Suspension
- Illumina Shock Install *Help*
- looking for site/place
- help!!
- question
- wiring problems...
- Best Plug gap for Crx
- Another Ac ?
- michene shops
- Newbie Wheel question
- pedal assembly
- CEL is off! But, still throwing Code 21 (Eg/GSR Hybrid)!
- machine work
- SHYZA!! Throttle cable..*Pics*
- Florida Mini-Meet
- Gas milage....
- best B16A swap?
- Wiring a GSR cluster into an Eg. Need some help / clarification!
- vtec prob
- Stupid Questions
- teg mirrors on ek
- anyone help find a shop
- intergra dash in civic
- Help me...
- I hate my Prelude!!!
- wanted to know
- prelude
- diffrences between b18a and b18b head
- Dyno
- Ac Help!
- important please help
- Was throwing just code 22. Now, 22 is gone and it's CEL code 21, Why?
- Wheel hopen question
- how to make a backfire, good kind????
- another damn problem
- back fires
- skyline R33 or black widow I kit??
- What is Tanabe's website?
- I need to borrow an obd2 b-series vtec distributor...
- Prelude owners
- need help with axels
- Vtec not functioning right
- Rebuilding a Head..
- wat do i need 2 go from auto 2 stick?
- D16z6 into a D15b2 89' HB problems
- valve job
- hondata
- Radiator fan fuse has NO power under hood fuse box!
- crank angle sensor????
- Aggr Help Tie end bolts spining wont go back on!
- trowing a couple codes please help
- Port, Polish and 3 Angle Valve Job????
- Oil Changing
- LS Buildup
- How do you wire the radiator fan to an accesory such as the radio?
- revving problem please help
- What the hell happened?
- 1995 Acura GSR
- CV Axles??
- steering rack trouble!!
- b16a3 block
- Need an engine immediately
- tossing code
- stripped exhaust mani bolt
- honda owner question.......
- Is this the right harness for CEL diagnostic? Pics inside!
- PW0 or PR3
- Any Hondas Coming To The Track Day ?
- springs question
- head flow rate??
- 99sohc vtec in a 90crx
- welded differential?
- Question fo all you LS/VTEC fans
- vtec being a bitch
- converting hydro to cable
- Greddy 20g B16 Turbo kit??
- Brake Conversion
- b16b ecu
- H22a Euro-R Accord vs H22a Jdm Prelude
- H23 Turbo setup
- Honda Accords?
- build up question
- Generation down from the 88's..
- Place to get a bung made on a header
- Brake lights not working??
- RPM tach for vtec???
- RECALLS On My Civic!! LOL...
- "bog.. or stutter"
- gsr head on b16?
- Intake Mani Tech...
- bad thermostat???
- swap price
- integra queations kinda
- Where did YOU tap in to wire the IAB (secondary intake solenoid) for vtec???
- specs for a prelude?
- Eg / GSR swap is almost complete! Few various Q's with pics inside!
- ls/vtec idle problem
- Pretty ghey but....
- vtec controller diagram help please
- Proper EGT's for a Civic?
- Integra swap..
- ECU Wires
- h23 swap into civic
- Green harness under intake manifold on GSR motor?? IAB solenoid?? PICS inside!
- Hose coming out of firewall, what is it? Pics inside!
- 89 prelude performance help
- Question (ITR Cluster Install)
- Installing the "bitch pin" (shift linkage at tranny), Best way?
- Clutch install
- question about a swapped crx
- LSD on a GSR
- Link
- need help pls
- Water Temp Guage
- will integra springs fit civic?
- suspension
- when doing engine swap
- air shifter
- lightest hatchback??
- dart blocks
- soo what has everybody done
- how do u do this?
- h23-h22 parts
- type-r head
- What size/brand tires???
- 93 Civic / 98 GSR motor! vtec wiring - I need help!
- 96 del sol si harness = 96 ex harness?
- spring question
- 2001+ Civics and Apexi VAFC Warning
- field sfc-vtec into EK civic ex
- Integra Owners: Integra Meetup Saturday
- Dyno Place?
- Pre OBD B16A
- car won't start
- dyno tuning?
- how would i??
- n e body konw scca racing?
- honda fans
- head specs
- Hot girl needs help working on CRX
- ::Pole- What kind of springs should I get?
- Window Molding Mold
- GSR distributor?
- Overheating Help
- Wheel bearing
- code 23 knock sensor on my pr3!! help
- 96+ civic grill
- Vaccum and compression..
- finding a motor
- cluster fitting?
- standard or oversized ITR Pistons?
- what do you guys think of these fogs?
- 03 Type R civic
- Wont hit above 5grand..
- Compression question
- 97 prelude bolt pattern?
- ....throttle cable sticking
- intakes
- can i get a one timeeee
- Idle problem plzzz help...
- check code on acura
- h22 vtec
- What fits..
- GSR idle question
- Alittle on the warm side
- 97 Type-R B18C swap
- b16 vs b18c
- yet another question
- does anyone have a external blaster coil on a 99-00 civic ex?
- Sunroof repairs
- vtec distributor???
- 99 civic ex turbo?
- Is LS-Vtec Good?
- Stupid ?
- Insight
- factory stereo CODE for Si
- what kinda power with this setup?
- Headlight bulbs for 92-95, size/model?
- Spring companies... 1" drop?
- O2 Sensor Question?
- Cronic
- Theft damage
- need sohc v-tech
- EK Civic Ex front disc brake FYI
- Honda challenge.........
- ls swap in89 hatch
- B2o swap!!
- what kind of axels for first gen b16a?
- D15B2 mods???
- code 43 d16z6
- obd 0 alternator to obd 1
- Not The Alt
- Check Engine Light PLEASE READ!!
- D15b 3 stage vtec
- eg to ek
- Best Gas Place?
