+ Reply to Thread
Results 1 to 3 of 3
  1. #1
    Registered User AP Tires has a reputation beyond repute AP Tires has a reputation beyond repute AP Tires has a reputation beyond repute AP Tires has a reputation beyond repute AP Tires has a reputation beyond repute AP Tires has a reputation beyond repute AP Tires has a reputation beyond repute AP Tires has a reputation beyond repute AP Tires has a reputation beyond repute AP Tires has a reputation beyond repute AP Tires has a reputation beyond repute AP Tires's Avatar
    Join Date
    Dec 2006
    Location
    Tampa, Florida
    Posts
    258
    Feedback Score
    1 (100%)
    PFADT performance parts for 2010+ Camaro
    Pfadt Coilover for 2010+ Camaro
    This setup features 1.5 inches of ride height flexibility, 20-clicks of damping adjustment and a long list of technical features which combine to give incredible road holding ability with unmatched ride quality. Both the front and rear shocks in the Pfadt 2010 Camaro Coilovers utilize a mono-tube, inverted design with a floating piston to separate the shock fluid from the pressurized nitrogen.
    Call us at the shop for a price quote. We might have a great deal for you!!
    Advance Performance Tires and Wheels
    (813) 868 1100
    4011 W Linebaugh Ave
    Tampa, FL 33624
    www.advanceperformance.com
    AIM: aptires
    E-mail: onlinesales@advanceperformance.com
    Wheels - New and Used Tires - Custom Alignments - Brakes - Suspension - HID Kits
    Tein - KW - Vossen - AME - Donz - Work - MRR - MSR - NZO - Strada - Hipnotic - Diablo - Gianna - Ace - Falken - Hankook Master Distributor - TireRack.com Five Star Preferred Shop.
    Have a question about our services? Feel free to ask.
  2. #2
    Join Date
    Dec 2006
    Location
    Tampa, Florida
    Posts
    258
    Feedback Score
    1 (100%)
    Rear arms for 2010+ Camaro
    Reduce Weight, friction and deflection, increase strength and durability!!
    Here is some specs for the arms:
    Increase strength by 106% while simultaneously reducing mass by 17%. The decrease in trailing arm mass allows the suspension to react more quickly to the changing road surface keeping the tire in contact with the road to increase traction. Through further analysis and testing we were able to achieve a 32% reduction deflection which helps decrease wheel hop and increase traction.
    Included with this kit is the leading edge Trailing Arm Bushing Kit and Rear Tie Rod Bushing Kit. Utilizing lightweight 6061-T6 aluminum sleeves that are hard anodized to create incredible surface hardness and microscopic pores to hold our special grease. These sleeves are then Teflon coated to further reduce friction. This is then coupled with our graphite impregnated polyurethane bushing which uses deep grease grooves to hold and continuously re-lubricate the surfaces for long and quiet operation. The result is an ultra lightweight, ultra-low friction joint that is 42% lighter than the OE bushing and more durable then ever before. This kit includes the bushing for both the trailing arm and also the upright for a complete performance trailing arm upgrade.
    (813) 868 1100
    Tampa, FL 33624
    AIM: aptires
  3. #3
    Join Date
    Dec 2006
    Location
    Tampa, Florida
    Posts
    258
    Feedback Score
    1 (100%)
    2010+ Camaro rear Diff bushing
    Pfadt Differential Bushings hold the differential in place by replacing the soft factory rubber bushings. The kit will help protect the differential and is an absolute must for handling the added power of a super charger or high horsepower motor.
    Made in the USA our bushing and sleeve kit provides superior quality and durability. The sleeves are made from 6061 T6 aircraft aluminum and anodized orange.
    An important upgrade for dialing-out wheel hop, this kit is a great addition to any performance Camaro. The installation is involved, but the results are well worth the effort.
    This kit includes bushings designed for performance street use. While these bushings are much stiffer then the factory bushings they still allow enough vibration absorption that differential noise is kept to a minimum.
    (813) 868 1100
    Tampa, FL 33624
    AIM: aptires
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
