+ Reply to Thread
Results 1 to 2 of 2
  1. #1
    Registered User AP Tires has a reputation beyond repute AP Tires has a reputation beyond repute AP Tires has a reputation beyond repute AP Tires has a reputation beyond repute AP Tires has a reputation beyond repute AP Tires has a reputation beyond repute AP Tires has a reputation beyond repute AP Tires has a reputation beyond repute AP Tires has a reputation beyond repute AP Tires has a reputation beyond repute AP Tires has a reputation beyond repute AP Tires's Avatar
    Join Date
    Dec 2006
    Location
    Tampa, Florida
    Posts
    258
    Feedback Score
    1 (100%)
    Advance Performance is a direct PFADT dealer.
    We get PFADT products direct. PFADT Offers great products for both Corvette and Camaro. For prices and installation quote, please give us a call.
    Advance Performance Tires and Wheels
    (813) 868 1100
    4011 W Linebaugh Ave
    Tampa, FL 33624
    www.advanceperformance.com
    AIM: aptires
    E-mail: onlinesales@advanceperformance.com
    Wheels - New and Used Tires - Custom Alignments - Brakes - Suspension - HID Kits
    Tein - KW - Vossen - AME - Donz - Work - MRR - MSR - NZO - Strada - Hipnotic - Diablo - Gianna - Ace - Falken - Hankook Master Distributor - TireRack.com Five Star Preferred Shop.
    Have a question about our services? Feel free to ask.
  2. #2
    Join Date
    Dec 2006
    Location
    Tampa, Florida
    Posts
    258
    Feedback Score
    1 (100%)
    New PFADT Featherlight Coilovers
    Specs:
    INVERTED DESIGN: Placing the majority of the mass on the sprung side of the chassis allows the control arms and outboard components to react quicker and easier without the additional weight of the coilover itself. The result is a suspension system that responds faster to changes in the road whether its highway, local roads, or track surfaces. The less weight that is on that outboard suspension, the better your car will behave – you’ll have a better connection between your Corvette chassis and the ground. Make sure your next set of coilovers are inverted.
    LIGHTWEIGHT, HIGH STRENGTH MATERIALS: Gone are the days when coilovers need to be made of corrosive steel components. The Feather Light Generation SAs are an all aircraft aluminum body which boasts high strength and very low weight. With the body and spring perch being manufactured out of anodized high-strength aluminum, you no longer have to worry about corrosion locking the two together. The materials in the new SAs allow pain-free height adjustability with ease with our threaded body. All non-aluminum components (upper mounting stud, lower mount mono-ball) are treated with corrosion-eliminating processes such as chroming, heat treating or using stainless steel. Don’t settle for heavy steel components.
    BOA MOUNT, THE NEW STANDARD IN CORVETTE SHOCK UPPER MOUNTING: An idea taken directly from its much more expensive bigger brother, the Feather Light Generation DA; the new BOA mount is a no-compromises solution to Corvette shock upper mounts. Our mount is a zero-maintenance, completely sealed design that allows the FULL articulation required for the Corvette suspension. A common problem in coilover mounting for the Corvette is how to effectively mount the upper shock to the chassis without losing much shock travel and articulation. Common solutions are a clevis design that severely limits shock travel and will effect ride quality, and a “pin top” design that relies on compliance in consumable rubber bushings to deflect and bind the shock, creating an unsealed mount needing eventual replacement. The BOA MOUNT suffers none of these shortcomings as it is a solid mount similar to a control arm ball joint (quiet, durable, maintenance free), that is locked in place and then articulates with the suspension utilizing a low friction internal monoball that is sealed from the exterior elements. On top of all of this, the installation procedure could not be any easier. A simple easy to torque washer and nut retain the whole assembly. If your coilover doesn’t have the BOA mount, be aware of the potential future problems.
    THE CIRC SYSTEM, A REVOLUTION IN REMOTE CANISTERS: A premium feature on the SAs that is unique to Pfadt is the CIRC (Concentric Integrated Remote Canister) System. The idea behind this innovation is to implement a standard racing concept – the remote reservoir – in a lightweight, easy to install package. We integrate the remote reservoir with the shock to maximize suspension stroke for a very smooth ride on the street. The CIRC more than triples the gas volume over a standard coil over. Accomplishing this was no small feat because the remote canister is actual mounted radially AROUND the shock body itself. The result: a large gas volume that keeps the shock operation consistent over a wide temperature range and throughout the stroke. The bottom line: Consistency and performance over the life of the shock. This system permits the entire shaft/piston assembly to operate quickly, efficiently, and last a VERY long time as wear is at a minimum. Get the most advanced racing remote canister on the market for your street suspension. Anything less is a compromise in ride quality. Take a look at the following illustration to see how we package the upper BOA MOUNT and CIRC SYSTEM for maximum shock travel and extreme lowering.
    EASY ONE-STEP RIDE HEIGHT ADJUSTMENT: We make ride height adjustments easy to give you the ultimate control in setting your ride height and corner balancing your car. Included in our coilover kit is the single tool that you need to adjust the perch and tighten the set screw to lock the perch in location. Very simple, strong, and reliable. This single perch adjustment is a result of having ALL of the suspension travel required for the Corvette built into the shock body, since features like the BOA MOUNT and CIRC SYSTEM are used to maximize travel and stroke. Any other design is forced to limit the travel range. Our design is the most optimum for the Corvette and will deliver repeatable results time and time again.
    FLOATING PISTON INTERNAL DESIGN: The most effective internal design for a performance shock that needs to last a lifetime of street use is the floating piston design, or “non emulsion” design. This design separates the oil volume from the gas volume and allows each to operate consistently despite changes in external conditions. In a standard emulsion shock, the oil and gas are free to mix together and can result in inconsistent performance when operating at low speeds and high speeds respectively. This is not good for the operation of the shock, as inconsistent performance correlates to inconsistent control of your Corvette’s wheels and suspension. Enter the “floating piston” style that isolates the two volumes and moves freely within the shock cylinder. Our floating piston design utilized in the Feather Light Generation SAs will keep your Corvette’s suspension predicable and controllable for a precise feeling on the street and track. GM’s Z06 and Z51 shocks don’t have oil and gas compromises, neither should your coilovers. Be sure to run floating piston shocks on your Corvette. Take a look at the diagram to see how the designs differ.
    For pricing just give us a call at the shop.
    (813) 868 1100
    Tampa, FL 33624
    AIM: aptires
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
